Author Topic: The freerouter that interfaces with kiCAD  (Read 4846 times)
Offline Simon
  • Global Moderator
    • Simon's Electronics
« on: September 22, 2011, 07:21:09 pm »
Well i have gotten into the habit of using the freerouter thingy that interfaces with KiCAD to route boards, it helps me optimize layouts as I'm happy to not take the first option and go back and move stuff around. It is good that it tries so hard and will run even thousands of runs but at what point does it stop ? I've done more than 3100 passes on a board and at the moment it is just "oscillating" between 2 options as it can't route all of the connections, will it ever give up ? when do i stop it ?
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear and Wurth Elektronik Books.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Offline djsb
Re: The freerouter that interfaces with kiCAD
« Reply #1 on: September 24, 2011, 08:47:50 pm »
Just stop it and route the remaining connections yourself. Simples.
David.
Hertfordshire,UK
 University Electronics Technician, London PIC,CCS C,Arduino,Kicad, Altium Designer,LPKF S103,S62 Operator, Electronics instructor.  http://debuggingrules.com/ Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime.
Offline cyberfish
« Reply #2 on: October 16, 2011, 06:01:10 am »
The autorouter sometimes gets stuck.
Usually you can see where is the culprit (it will be a very crammed place near the trace it's trying to route). Can usually be fixed by making more space there, and just restarting.
Offline Simon
  • Global Moderator
« Reply #3 on: October 16, 2011, 07:12:19 am »
Yea that's what I've started doing
