Author Topic: Creating filled zones for thermal pads.  (Read 315 times)
Offline cbowen
« on: June 09, 2019, 10:34:09 pm »
Hey all. I've created a footprint for a SM LED that has 2 anode and two diode pads on each one. It also has a thermal pad on the middle underneath it, which I created as "pad 5". The problem is, when doing filled zone, I can't seem to find a way to select zone 5 as the net. I'm guessing this is because this pad has no traces connected to it. How would I go about getting pad 5 connected to the filled zone? Thanks everyone!
Offline tox3
  • Country: lv
  • Country: lv
Re: Creating filled zones for thermal pads.
« Reply #1 on: June 10, 2019, 06:59:39 am »
Check datasheet, where you can connect it. Usually ground. And then you will be able to create zone
Online thinkfat
    • Matthias' Hackerst├╝bchen
« Reply #2 on: June 10, 2019, 01:11:06 pm »
If you cannot connect the pad to ground, just make up a net name for it to connect to and use it for the copper fill.
Gesendet von meinem Nokia 6.1 mit Tapatalk
