Electronics => PCB/EDA/CAD => KiCad => Topic started by: opampsmoker on October 27, 2020, 08:10:30 pm
Title: Multiple sheet schematic in Kicad?
Post by: opampsmoker on October 27, 2020, 08:10:30 pm
I have 4 sheets in my kicad schematic.
Kicad has made a "sub-project" for the three added on sheets.
Is this right?
It feels unwieldy. I presume i have to push each separate  sheet through to PCB?
Title: Re: Multiple sheet schematic in Kicad?
Post by: golden_labels on October 28, 2020, 03:33:04 am
Is each of them describing a separate PCB?
If yes, this is ok — after all you will generate separate netlists, footprint assignments, PCB files, gerbers and probably other files.
If no, you probably want hierarchical sheets. There are a few buttons on the toolbar to create them and the associated labels.
Post by: opampsmoker on October 28, 2020, 07:18:42 am
Thanks,
Incidentally, is there a way of having multipel sheets in a schematic without having heirarchical sheets?.....i  want to keep the heirarchical sheets for small subcircuits which are repeated often. Though i still want extra sheets which are not heirarchical.
Post by: AndyC_772 on October 28, 2020, 09:27:14 am
Does KiCad really still have that limitation that no schematic can span multiple pages without having each individual page as a hierarchical block?
Post by: hli on October 28, 2020, 10:13:37 am
https://docs.kicad-pcb.org/5.0/en/eeschema/eeschema.html#flat-hierarchy
Having that one root schematic is not so much of a hassle. Would be nice to skip it, but adding it is also not a great deal. There are more important things to improve.
Post by: AndyC_772 on October 28, 2020, 11:16:08 am
So, say I'm developing an 8 channel product, in which each channel is 3 pages' worth of circuitry.
In OrCAD, I create a 3 page schematic which contains the circuit for each channel. That schematic uses off-page symbols (or even just common net names) to link the nets within each channel, and hierarchical ports to expose the signals that need to be visible at the top level.
Then, I create a top level schematic which includes 8 identical instances of the per-channel circuit (ie. 8 identical blocks), and joins them to the common power, processor etc.
How would that design be done in KiCad?
Post by: MitjaN on October 28, 2020, 03:50:07 pm
I agree that lack of support for multipage same level hierarchy in KiCad is somewhat limiting, but we get what we pay for.
If you have multichannel design, you'll probably want to replicate layout (AD rooms, I don't know what is called in OrCad). I'd go this way:
1. create 8 hierarchical sheets in the main (root) sheet to hold the channel schematics. Point each sheet to the same schematics file
2. in each channel sheet create 3 hierarchical subsheets where you split the schematics for one channel. You'll have to link the nets via hierarchical labes and connectors though. Using global labels will not work as you have a multichannel design.
Post by: golden_labels on October 28, 2020, 04:10:04 pm
As hli has noted above (https://www.eevblog.com/forum/kicad/multiple-sheet-schematic-in-kicad/msg3299676/#msg3299676), you can have as many sheets as you want. KiCad is also supporting global labels, which are shared among all sheets. All additional work you have to do is add a single root sheet that will group them all.
Post by: SiliconWizard on November 10, 2020, 03:22:37 pm
I also find that quite limiting. Or at least I used to think that.
The plus side (even if that might not have been the original reason) is that it forces you to design your schematics in a more hirerarchical way (if you use that properly), which IMO (but probably not everyone will agree) is a good thing.
So each "sheet" should be self-contained, and actually more easily reusable (it looks cleaner and better than just copy-and-pasting.)
Now the fact each hierarchical block can't span several "sheets" is still limiting, but here again the plus side is that it forces you to split your design into blocks of reasonable size and thus, more easily manageable and less prone to mistakes.
Of course, YMMV.
