Author Topic: Using Kicad PCB editor without a netlist.(solved)  (Read 9820 times)
Offline HackedFridgeMagnet
« on: March 20, 2012, 12:08:03 pm »
Hi
I think this may be an easy one for experienced Kicad users.
I have a very large but simple circuit with stacks jof repetition, It's a MCPCB panel for leds, nothing else.
I want to add tracks to the pads of my led models but can't seem to do it because there is no netlist.
Is there a way around this? (Without a netlist.)
Also can I just lay pads down in Kicad? I can't see a way of doing this.
I am using the stable build of 19th Jan 2012
« Last Edit: March 20, 2012, 12:53:00 pm by HackedFridgeMagnet »
Offline amspire
Re: Using Kicad PCB editor without a netlist.
« Reply #1 on: March 20, 2012, 12:39:32 pm »
Did you turn DRC off on the Preferences->General first? By default, KiCad does a live DRC check, so it will not let you do anything that is not specified in a netlist.
Turn DRC off, and you can add parts and tracks without any complaints.
Richard.
Re: Using Kicad PCB editor without a netlist.(solved)
« Reply #2 on: March 20, 2012, 12:53:33 pm »
Thanks
That's fixed it.
