Author Topic: KiCAD issue - Cannot make changes to a single gate in a multi-gate component.  (Read 6429 times)
Alex
  • Guest
Hi all, I am making a library in KiCad. The component needs to have two gates.
I create a new component and assign two parts to it in the preferences. Part A and part B selection becomes available.
I draw up part A but when I select and make changes to Part B these changes are also applied to part A. I have made other libraries in the past, anyone heard of this issue?
« Last Edit: December 08, 2011, 06:27:06 pm by Alex »
Offline djsb
Are you using the latest stable version or a testing version off the launchpad site (see my other post about compiling KiCAD for Windows)? If there is an issue you can check on Launchpad (https://bugs.launchpad.net/kicad) or have a look at the Yahoo kicad-users group (http://tech.groups.yahoo.com/group/kicad-users/). I havent tried what your doing, so I can't confirm this issue myself.
David.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Alex
  • Guest
Thanks for the reply David. I was not able to find any reported bugs on that link. I downloaded it from here:
http://www.lis.inpg.fr/realise_au_lis/kicad/
I am really not the type of user that will compile his CAD package in order to use it and eliminate bugs. :)
Are you aware of a place that hosts the latest compiled version?
I will also post on the kicad yahoo group I am part of.
Offline amspire
There is always this forum.  :)
I have been posting recent builds occasionally. I will compile the latest. I haven't done a new version recently, but I will put build 3825 3285 up later today, if it looks OK. (Some of the testing build have had new bugs, so I haven't been posting all of the newly compiled versions I have built).
Richard
« Last Edit: December 09, 2011, 01:00:07 pm by amspire »
Alex
  • Guest
Do you mean build 3285 amspire?
Thanks, at least I can rule out that there isn't a problem with the installed version.
Offline amspire
Corrected now. Thanks for pointing it out.
Offline gxti
Double-click on the objects you don't want to share and make sure that "Add to all parts in package" (if it's a pin) and "Apply changes to all parts in component" (if it's a drawing) are unchecked. I'm on revision 3047 so this may or may not still apply to you.
Offline amspire
That sounds straightforward. Thanks.
The last official build was 3044. Does 3047 fix some bugs? Looks like it added eeschema sheet resizing at least.
Richard.
