Author Topic: Hacking the KiCAD Libaray system to be actually useful  (Read 26887 times)
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Hacking the KiCAD Libaray system to be actually useful
« Reply #50 on: April 26, 2019, 10:04:59 am »
I'm confused. I thought you could now specify a footprint in a symbol? Yes footprints and specific part numbers all need to go in on the schematic so that a BOM can be easily produced and ordered. An yes when it gets to things like elecy capacitors you have to have a symbol per port number as it becomes important as to what part you have chosen.
Offline mkschreder
« Reply #51 on: April 26, 2019, 10:15:58 am »
KiCads library system makes very little sense unless you hack it Simon and do what I do in this video: https://youtu.be/5-GwQi7LG-A
I modified how kicad updates fields to make my life easier. Basicaly the rule is: never modify the part on the schematic - not even the value - do everything in the library and then update ALL fields besides the designator.
Sent from my SM-G960F using Tapatalk
