Electronics => PCB/EDA/CAD => KiCad => Topic started by: bd139 on January 18, 2018, 12:35:48 pm
I've got a 4027 which I've tied both Sd to ground on. gnd is marked with PWR_FLAG. This is an input pin in theory but the ERC is showing error as follows:
(https://i.imgur.com/ElQ8gyj.png)
Schematic:
(https://i.imgur.com/ysaM9Pk.png)
In theory the Sd pin should be both grounded and both inputs.
Any ideas how to proceed on this one to pass the ERC? Is this a bug in the symbol i.e. the pin should be an input?
Edit library... Change the state of that pin
That did the trick. Bug in kicad library then!
Thank you :)
Thank you :)
The fact you ground them for your application doesn't make this a bug. The data sheet I'm looking at says "1SD, 2SD
9, 7 asynchronous set-direct input (active HIGH)". Why would the library list it as a power pin?
https://www.intersil.com/content/dam/Intersil/documents/cd40/cd4027bms.pdf (https://www.intersil.com/content/dam/Intersil/documents/cd40/cd4027bms.pdf)
Page 6. IC schematic. Definitely inputs. Were marked as outputs in library.
I found several issues like this when I reworked the CMOS library, it should be fixed in the latest version.
Cool. Thank you :-+
