Electronics => PCB/EDA/CAD => KiCad => Topic started by: phil from seattle on November 01, 2020, 11:34:32 pm
Title: spontaneous lost junctions in eeschema
Post by: phil from seattle on November 01, 2020, 11:34:32 pm
I'm not sure what it is I am doing wrong but I seem to lose junctions in eeschema.  This has happened 5 or 6 times in the project I'm currently working on and happened again just now.  I was tweaking my layout and went back and forth between eeschema and pcbnew a couple of times.  When I ran DRC (which I do frequently) it complained of an overlapping problem.  I notices that the errant trace ended in a via to "nowhere". Looking at the schematic, the pin had lost it's junction.  It wasn't that way 10 minutes earlier.
I had added a resistor and placed/routed it but then changed my mind and deleted it.  Some how this lead to the lost junction.  Is this a known problem? The resistor did not connect to the lost junction and wasn't even on the same schematic sheet.
Title: Re: spontaneous lost junctions in eeschema
Post by: Benta on November 02, 2020, 06:08:31 pm
I've had the opposite problem: spontaneously added junctions on crossing connections in Eeschema. I haven't found a bug report, but pay special attention to junctions when editing schematics.
Post by: nfmax on November 03, 2020, 08:33:02 am
I've hit that one as well, since the latest 5.1.7 version. Only happens rarely, and seems to be related to dragging (G) a block. Watch out for it!
Post by: retiredfeline on November 03, 2020, 08:43:58 am
I have often created spurious junctions by moving blocks, and this has been so since I started using KiCad. I suppose junctions could be lost too but I haven't encountered that. Just something to watch out for when moving blocks.
