Author Topic: KiCad Panel Appending Eagle PCB Problem  (Read 2687 times)
Offline t1dTopic starter
« on: December 10, 2017, 06:30:09 am »
I am creating a panel, in Kicad. I am appending it with boards created in Eagle. I am receiving the following notice:
Error loading board.
IO_ERROR: Unknown file type
from legacy_plugin.cpp : checkVersion() : line 571
I am guessing that I need to change the footprint designation in Eagle to something else. But, what and how?
I did not find it in the manual and Google let me down.
Please explain the problem and give me detailed instructions on how to correct it.
Thank you.
Offline hermit
Re: KiCad Panel Appending Eagle PCB Problem
« Reply #1 on: December 10, 2017, 07:32:30 am »
I think the coming version of Kicad will import Eagle files directly.  What version of Kicad are you using?  There are several scripts currently for importing boards that I just saw mention of on the Kicad forum.
« Reply #2 on: December 10, 2017, 08:36:56 am »
I am using KiCad 4.0.7, which is the newest, I think. It does append Eagle footprint files, but only with a particular designator. The "Legacy" designator is the problem. I need to know how to change it in Eagle. At least, that is what I think is going on. I'm not sure, so I asked for help.
Offline hermit
« Reply #3 on: December 10, 2017, 05:10:13 pm »
https://forum.kicad.info/t/open-sch-in-kicad/8775/7
Check out post 7.
"You could also try https://github.com/bobc/eakit, I think it is the best Eagle to KiCad converter but then I wrote it :slight_smile: However, it does have some features others lack."
If you don't get your answer here you might try there.  Someone like BobC that wrote the import script might have a better handle on what's going on.
« Reply #4 on: December 10, 2017, 07:27:15 pm »
Thank you, good sir; your program seems to have been the cure, for the ills! I am most impressed and grateful! Kudos!
Offline hermit
« Reply #5 on: December 10, 2017, 09:08:12 pm »
Just to be clear, I didn't write that. My coding skills are just barely this side of non-existent.
