Electronics => PCB/EDA/CAD => KiCad => Topic started by: Curby on May 01, 2019, 12:37:55 pm
I'm using the current version of KiCad. Is there a way or a script to create independent libraries and footprints of the current project in the project directory? At the moment i do it by hand, copying every footprint, create an own librarys and redo the assignement.
Is it possibile, to change the size of all references at one time to a different font size? Is there a possibility to create own layer and put them in the plot?
Thanks a lot!
In pcbnew there's a menu option to Edit -> Edit Text & Graphic Properties... this will do it. Select what you want to change and enter new dimensions. If the current dimensions vary it box will say <...>; just enter a new value.
Take a look at https://github.com/MitjaNemec/Kicad_action_plugins#archive-project (https://github.com/MitjaNemec/Kicad_action_plugins#archive-project)
Use kicad library utils. Its a set of pythons scripts that can load kicad files and manipulate them. They are completely independent from kicad.
Sent from my SM-G960F using Tapatalk
