Author Topic: Rules checker fails for barrel jack  (Read 4254 times)
Offline YurkshireLadTopic starter
« on: March 12, 2021, 10:00:10 pm »
I'm trying to add a barrel jack to my schematic, but I'm not sure how to wire it up. It's currently wired as shown in the attachment, but KiCad's rule checker says:
Pin 3 (power input) of component U1 is not driven (net 5)
Pin 1 (power input) of component U1 is not driven (net 7)
I assume I'm doing something wrong but I can't work out. Any suggestions appreciated.
Thanks
Offline golden_labels
Re: Rules checker fails for barrel jack
« Reply #1 on: March 12, 2021, 10:12:57 pm »
The type of pins 1 and 3 of LM1117 is “power input”. Nets that connect to those pins must be connected to the PWR_FLAG element (from the “Place power port” button).
People imagine AI as T1000. What we got so far is glorified T9.
« Reply #2 on: March 12, 2021, 10:50:04 pm »
Thanks. I put it after the diode, if that makes sense.
Offline retiredfeline
« Reply #3 on: March 12, 2021, 10:57:48 pm »
There's a FAQ with far more detail than you might have bargained for here: https://forum.kicad.info/t/errtype-3-pin-connected-to-some-others-pins-but-no-pin-to-drive-it/10946
Although most occurrences are related to power handling components, sometimes they are not so I prefer to think of PWR_FLAG as a Relax, ERC, This Net Is Driven flag.
The following users thanked this post: poeschlr, YurkshireLad
« Reply #4 on: March 13, 2021, 09:38:19 pm »
Yes, this is the net that must be flagged as providing power.
In this schematic it may seem as a nuisance that is cluttering the diagram and the PWR_FLAG is placed near the component only to tell ERC to shut up. But this is not the case for larger circuits. In such scenarios you will have a power supply section, which will provide power rails to the rest of the circuit. Those rails (nets) will be marked as supplying power only in that section — nowhere else in the schematic. Also note that voltage regulator components usually have their outputs marked as power outputs, so no additional PWR_FLAG is needed.
« Reply #5 on: March 13, 2021, 09:44:43 pm »
Thanks all.
Offline phil from seattle
« Reply #6 on: March 15, 2021, 03:36:57 am »
Sometimes you just have to ignore ERC/DRC. In the end, it's your design and you should understand what works and what doesn't. There are a number of symbols out there that have questionable choices of pin type. Knowing the circuit, I just ignore the error.  Also, I have a couple of connectors that the courtyard is just a little too large and gets flagged in DRC when I butt them together. Since I know it's not a problem, I don't bother to go back and update the footprint. It forces me to go and verify spacing.
