Electronics => PCB/EDA/CAD => KiCad => Topic started by: NivagSwerdna on March 04, 2022, 04:23:33 pm
Title: Trying v6... (nightly)...
Post by: NivagSwerdna on March 04, 2022, 04:23:33 pm
I thought it was about time I looked at v6... downloaded nightly...
When adding a global label I now get "?" symbols?
What does that signify?
[attachimg=1]
Title: Re: Trying v6... (nightly)...
Post by: woofy on March 04, 2022, 04:36:57 pm
I'm running Kicad 6 and I'm not seeing that.
It's the release version not the nightly though. It may be something new they are testing.
Post by: NivagSwerdna on March 04, 2022, 04:51:41 pm
Ah OK... maybe I should go to v6 stable
Thx for the response
Post by: ataradov on March 04, 2022, 05:22:12 pm
v6 stable for sure. Nightly is in a heavy development cycle. Things change every day. Nightly builds become more or less stable once they become release candidates.
Post by: nctnico on March 04, 2022, 05:30:00 pm
In other CAD packages you can have sheet references (to see where the signal goes / is coming from) at that place so I guess that is a Kicad feature that is being worked on.
Post by: janoc on March 04, 2022, 08:02:12 pm
(Attachment Link)
That means that some symbols from your schematic haven't been found. Usually this happens when you are importing an older project and some libraries aren't available (e.g. because paths are not set up correctly).
If this happened when you were adding a label, which should be a built-in symbol, then that looks like a bug. Which is nothing surprising - nightly is not meant for general use. It is the bleeding edge code that is likely unstable and full of bugs and meant only for testing.
Post by: NivagSwerdna on March 05, 2022, 01:00:39 am
I gave up on the nightly... that was a poor plan.  Now have a 6.0.2 stable installation and sent my first attempt off for manufacture... we'll see.
Post by: thinkfat on March 05, 2022, 04:32:27 pm
The nightly builds were a good choice when KiCad was nearing the v6 release. Now they are only for the daring (or the desperate).
