Electronics => PCB/EDA/CAD => KiCad => Topic started by: canis_lupus on March 19, 2021, 11:55:36 am
Hi!
Does anyone have a proven pair of USB-C socket from aliexpress and a footprint to them?
If there is a datasheet that goes with the connector, you should be able to easily make a footprint.
Yes, i know, but cheap chinese shops send parts without any docs. :-)
The problem with what you are asking is that the vendors (like aliexpress vendors) do not have a consistent supply of parts so the USB connector [or any other part, for that matter] you buy from a given vendor may not be the same that someone else buys from that vendor. For what it's worth, you can find parts on eBay/Amazon/Aliwhatever that do have datasheets. I found a strip of 50 USB connectors on eBay years ago for a few dollars - there was a datasheet so I was able to make a footprint and it has worked just fine.
The second problem is that making up a footprint for a part like that without a datasheet is going to be hit or miss, probably taking some trial and error experimentation. I assume that is why you said "proven". But that seems a lot of effort to save a little money. As they say "penny wise,..."
Personally, I would not bother. USB connectors are not that expensive to begin with and you can get Aliexpress level prices from Chinese distributors - LCSC for example. It will have a datasheet. And they take PayPal. Shipping will probably more than double the cost to you but still pretty low. For example, at LCSC, C145792 (https://lcsc.com/product-detail/USB-Connectors_Korean-Hroparts-Elec-U-F-M5DD-W-L_C145792.html) is a micro-B connector for $0.114 USD each. Falls to $0.0853 USD in quantity 50.
For what it's worth, western distis have microUSB connectors for around $0.50 USD if you don't want to bother with Chinese distis.
Honestly, what the fuck do you expect?
That's expensive one. https://lcsc.com/product-detail/USB-Connectors_Jing-Extension-of-the-Electronic-Co-920-E52A2021S10100_C10418.html (https://lcsc.com/product-detail/USB-Connectors_Jing-Extension-of-the-Electronic-Co-920-E52A2021S10100_C10418.html) at $0.051 @qty of 50 is still decent. Cheaper connector from XKB https://lcsc.com/product-detail/USB-Connectors_XKB-Connectivity-U254-051T-4BH23-S2S_C482361.html is trash though.
Succinctly put though I still prefer my answer.
OK, you win the race to the bottom. Congrats!
I sampled cheap stuff to figure out what to buy at larger quantities.
USB-B
Good:
C456324 TXGA FUS213-FDBK6K
C46393 Jing Extension
OKish:
C386743 Ckmtw U-USBBR04P-F001
Bad:
C397338 XKB U241-041N-1BR85-1
C388656 XKB U241-041N-1WR85-5
C189733 Ckmtw
C46392 Jing Extension
micro USB type 1:
Good:
C91146 Korean Hroparts U-F-M5DD-Y-L
C10418 Jing Extension
Bad:
C319164 XKB U254-051T-4BH23-S2B
C482361 XKB U254-051T-4BH23-S2S
micro type 2:
Good:
C40943 Jing Extension (short)
C91467 Korean Hroparts U-F-M5DD-Y-1 (short)
Bad:
C386748 Ckmtw U-MICRM05P-BF13 (long)
C386747 Ckmtw U-MICRM05P-BF12 (short)
C319170 XKB U254-051N-4BH806 (long)
micro USB type 3:
Good:
C40946 Jing Extension
HRO Type-C-31-M-12 on LCSC: https://lcsc.com/product-detail/USB-Connectors_Korean-Hroparts-Elec-TYPE-C-31-M-12_C165948.html (https://lcsc.com/product-detail/USB-Connectors_Korean-Hroparts-Elec-TYPE-C-31-M-12_C165948.html)
Aliexpress clone: https://www.aliexpress.com/item/4000259156096.html (https://www.aliexpress.com/item/4000259156096.html)
KiCad footprints: https://github.com/ai03-2725/Type-C.pretty (https://github.com/ai03-2725/Type-C.pretty)
