Sometimes you can't beat some hands on fiddling.
The PBT is very high end for a manual printer, you might see it and think this is way over the top, the eBay chinese ones are super basic and very small and as you may have noticed... manncorp ones, also not cheap but may give you an idea of the kind printers out there, same goes for
http://www.pcbunlimited.com/t/smt-equipment/smt-stencil-printers/. The pricing suggested on some of these seems insane to me, you could probably get the parts custom machined for less in some cases. We build batches of boards between 1 & 250 most of the time and do all that on a manual printer way more basic than the PBT. The downsides are needing to jerry rig things for double sided boards because simple printers don't have a nice board holding/support system like that and holding the squeegee in your hands means the angle and pressure won't be as consistent as it might be with the squeegee is powered or mounted on a slide.
What about the Neoden PM3040 - from pictures only, looks slightly less crap than some of the other eBay/Aliexpress printers...
