usually the trick you need to do is figure out how to make the enclosure work for you, so you get rid of mounting hardware. Things like inserts (may have a machine to do it), bending metal creatively, etc.
Sometimes its not that the enclosure is that cheap, its that you saved the money elsewhere.
It's all a trade off. Do you need masking? Do the vent punch out need to be flat? can you have a seam?
Unless you know their place well, they basically have to figure out how to make your box with the equipment they have. It means there is a guy there that figures stuff out for money.
Its a hard subject because unless you know what machinery they have and what their employees are programmed to do, its hard for you to make a cheap design that suits them.
It's not like CNC where you can expect some router will follow a path, you need to 'know' things like what kind of bends whatever inserts in their bendomatic5000 works good enough for what you want.
I think its a massive headache.
Might not save money on just the box outside, but if you can figure out how they can make some superstructure inside the box to mount all your parts on with a minimum of screws, you might be in business.
Things that seem obvious/simple to you might make them go WTF because of whatever weirdo way they figured out how to make the parts themselves fast on their equipment (often highly modified/customized for specific big customers).
I absolutely
hate dealing with that shit. It is similar to understanding foreign law.
If you don't try to conform to whatever process they made up, you get hit with massive financial penalties. God forbid the guy feels like running the meter instead of helping you optimize.
I feel like its video game levels when there is a company thats been doing it for a while, they start to understand what the shop is doing, then they suspect MAYBE you can save money there and then you end up with some guy going insane trying to figure out some stupid shape they might be able to use.
Is it appropriate to shake someones hand after dinner, in ancient japan?
