Ah, well resin printers are a bit different. They are a bath of UV-cure resin with a high resolution monochrome LCD at the bottom which partially cures an entire layer at a time. Stereolithography I think is the term.
The main issue that I can think of is that they print upside down like a stalactite rather than stalagmite. Maybe just some double sided tape and suction cups would do given how quickly the .02mm/0.8mills will be applied.
Extruding a liquid out of a FDM printer sounds like it could get messy. But the thicker solder masks maybe aren't that far off the viscosity of plastics at printing temperature.
