Author Topic: "Arc lighters" and surface treating plastics for better adhesion?  (Read 770 times)
Offline e100
Has anyone used one of those electric lighters gadgets for surface treating hard to glue plastics such as PVC?
I don't want to burn the plastic, just change its surface chemistry.
https://youtu.be/voTVI0bL9C4?t=153
Are these things deadly to electronics?
« Last Edit: June 26, 2022, 02:50:55 am by e100 »
Offline Uunoctium
Re: "Arc lighters" and surface treating plastics for better adhesion?
« Reply #1 on: June 26, 2022, 03:28:43 am »
due to lack of purge gas flow this is not an cold plasma what's normally used for etching!
With such an arc lighter you will immediate burn plastics -  too hot
but you can modify it :)
https://siamagazin.com/a-cold-fire-torch-that-you-can-touch-and-not-get-burned-explained/
Offline e100
« Reply #2 on: June 26, 2022, 04:37:34 am »
Looks complicated to build and needs an argon or helium supply.
Would a normal stream of air going through the discharge of an arc lighter still allow the arc to form but keep it cool?
« Last Edit: June 27, 2022, 03:08:36 am by e100 »
Offline Marco
« Reply #3 on: June 26, 2022, 06:57:50 am »
I'd be scared of that electrode arcing to my finger in that demonstration in the video, the plasma might not burn it but a HF arc can be nasty.
Offline twospoons
« Reply #4 on: June 27, 2022, 05:03:03 am »
Its not really. Simple 2 transistor push/pull oscillator built around a tv flyback to give ~20kV @~20kHz.
Air works just fine. Probably even better for surface treating plastics - all those oxygen radicals do a great cleaning job.
Ideally you want to set this up for dielectric barrier discharge.
Years ago I built a low pressure version for treating LCP, and the increase in glue bond strength was incredible. LCP is one of those difficult plastics.
Offline e100
« Reply #5 on: June 27, 2022, 06:34:58 am »
How about an ozone generator. Is this the same principle with electrodes separated by a dielectric?
https://youtu.be/yfmWGl1DRWI?t=195
Online jpanhalt
« Reply #6 on: June 27, 2022, 09:48:18 am »
One can and I have used simple flame treatment with a propane torch.  That's an old technique.  There are lots of articles on it.  Here's one of the first to  pop up on my search: https://www.sciencedirect.com/topics/engineering/flame-treatment
For Teflon, I use a chemical etchant.
Offline Marco
« Reply #7 on: June 30, 2022, 08:57:09 pm »
Same principle, but ozone accumulates across that tube and plasma is already gone by the time it gets to the output. A cold plasma torch has to generate the plasma very close to the exit.
Advertise on the EEVblog Forum
