Author Topic: PNP for home use, any suggstions  (Read 1866 times)
Offline prutserTopic starter
« on: January 13, 2025, 06:29:45 pm »
I am considering a PNP machine for home use, after spending 4 hours to do PNP by hand on a small PCB with quite some 0402  and some 0.5mm pitch QFN. :(
For this reason I am considering some form of PNP machine.  I am looking for some suggestions for an affordable ($750 - $1500)  solution (if even possible)
Some requirements:
  • Open PNP compatible
  • A few feeders (2..4) would be nice, I do not mind placing some passives by hand, if e.g. placing decoupling capacitors and the common resistor values  can be done using a feeder it is already a a time saver.
  • As far as I understand: bottom vision is important for find pitch components
  • Are there models which can "grep" components from a kind of tray (I have most SMD components in small SMD containers)
  • Speed is not a concern, I expect is always saves a significant amount of time
  • 0402 (imperial) components should be possible
I have seen several projects and chinese machines on teh web, but it's hard to get a clear picture, so any insights are appreciated  ;D
[/list]
Offline jmelson
Re: PNP for home use, any suggstions
« Reply #1 on: January 21, 2025, 01:18:15 am »
I have an OLD commercial P&P (Quad QSA30A) made in about 2000.  It has 3 nozzles and an automatic nozzle changer.  A bottom camera was optional, it doesn't have it.  It does have flying vision, however.  There are line-scan cameras on each nozzle that sights across the part, and it gauges the dimensions and rotation/centering of the part.  It does an amazing job on 0.5mm lead pitch parts, placing them within about 0.1mm of perfect, and usually even better than that.  It also has a top camera for fiducial detection.  It also has servo motors for the Z axis on each nozzle, and places the parts very gently.  I do 0603 as my smallest parts, I don't even want to think about 0402!
Jon
