You can find some examples, I think smallsmt makes similar tables for own machines.
Personally, I would not use this; at least 80x80 (and 80x160 for a cross leg joins) for robustness and stability, and avoid wobbling and shaking.
Yes, I was thinking 40x80 at least but as this guy build aquarium cabinet for a living (some those large ones for shop display), so I thought maybe he knows what he is doing. But, I forgot about the machine inertia when it is moving. I think the SmallSMT ones are sized 40x40 for smaller version and 40x80 for the larger ones but their machine is not that heavy.
The table has a 10 mm thickness plate on top of it so the 4 legs will not move away as there will be 4 of 50 mm holes at the corner of the table. The feet of the machine will be removed leaving only some protruding welded nut sized around 50 mm. This is the part that will prevent the machine from moving/slipping on the table. The table has 4 wheel/feet combo.
Here's the image of the table drawing based on the sample table dimension. I think the empty space is for the feeder overhang. There will be right angle joints all over it.
