Every so often I need to produce a home-made pcb for prototyping. I try to stick with through-hole stuff when I can, but every so often I have no option but to work with smd. Last weekend I had the displeasure of having to hand-solder a 16 pin thin-lead tssop part. I hand-roll my footprints in Kicad to give me the best chance of success (fatter, longer pads when that makes sense), but even so it's a total pain.
Thinking about alternative ways to get the job done, I thought: wouldn't it be cool if you had a set of multiple-use, single component stainless steel stencils for more awkward package types. I'm actually OK to hand-solder quite a few smd package types, but the smaller ones are always a nuisance. The point is, I wouldn't need a complete board stencil, just ones that help me with the awkward ones.
So, I had a look around this morning and I came across these guys (
http://www.proto-advantage.com/store/index.php?cPath=3000_3200_3230), Proto Advantage stencils. I'm just wondering if anyone has used these and what their experience has been? One obvious disadvantage is that you need some clearance for the stencil. That might be OK, provided you remembered to get the stencil parts done first and I typically don't have crowded boards anyway. Thoughts?
