The chinese manufacturer also used a lead-free process, both were ROHS for the european market.
I understand the reasoning that moisture/liquid trapped inside a via that gets closed on both ends may evaporate and burst the solder mask. But that would have to be from liquids used during PCB manufacturing, wouldnt it? Once solder paste is applied the via is already closed on both sides and no paste can get inside. Regardless if this requirement is (still) relevant, at least its a reason that makes sense.
Its the "either completely open or completely closed" requirement that puzzels us..
I'm not sure what you mean by the last paragraph about the modified process & copper plating. As is understand, the inside of a via is always copper plated from the inside and then solder may be put on top of it.
The manufacturer that said either both sides open or both sides closed remains a mystery and they couldnt give me an explanation for this requirement other than "we always do it like this".
We came up with one other theoretical scenario when talking about it at the office, but its a bit far fetched.
If a via is only closed on one end and it that is "from below", the via is like a "cup" and solder paste could get in the via (but not much since the stencil doesnt have an opening there).
Now, when the bottom side gets assembled (and the "via cup" is upside down), the solder inside the via may set free gasses (that did not fully evaporate when reflowing the top side) on the side where the via is closed. Those gasses may be trapped between solder that is still solid and the solder mask and those cannot go anywhere and may crack open the solder mask.
hmmm.....hmmmm....
