Yeah the Eagle parts I had for the DC jack with slots were a bit iffy so I didn't use them. In the future I'll sort out a proper part with slots, but at the time I simply didn't care
Seeed Studios have updated their page:
http://www.seeedstudio.com/depot/fusion-pcb-service-p-835.html?cPath=185They've just clarified the whole panellising thing. Basically, they don't care what you do within the board space you pay for, but they will only separate the entire outline, and will not do drill lines or slots to make it easy to separate yourself
You can see on this board I've put two on one 5x5 board:
I only left 2mm of space though which isn't quite enough. 3mm should be perfect. I separate mine with an electric tile cutter (~$100?). Blade cutting width is 2.2-2.4mm and with the water tray it collects all of the fibreglass dust
Only good for straight cuts and making really tiny boards this way isn't really advisable since you would be putting your fingers awfully close to the blade
Oh and I did mention this in the shoutbox, but, Seeed are now offering an acrylic laser cutting service
Perhaps soon even a solderpaste stencil service. Sounds pretty good. Get your PCBs, stencils, and enclosures all made in the same place. Pricing looks very reasonable compared to places like pinoko.
Itead studios have made some changes as well. They now offer a 4 layer service, as well as expanding the size options for boards. They also offer a high volume (50-200) service which is comparable in price to Seeed's offering. I still find Seeed's single page much easier to use rather than a huge number of different SKUs. Too bad Seeed don't offer black soldermask
Black + ENIG gold = sexy.
