I guess I can spill the beans a little... I'm trying to build a 70s/80s microcomputer from scratch... I'm hoping to keep it as classic looking as possible...
Anywho, I can move the power supply to its own board, and move the memory/IO logic chips to a riser board, but the main board (containing the MPU, ROM, and half the RAM) still remains.
And it leaves out how I would interconnect all these PCB fragments. I was tinkering with the idea of making a backplane that other boards would connect to (UART/serial, the other half of the RAM, video, sound, maybe DMA... FDC... I'm getting ahead of myself here), but the only connection method I could think of that would provide adequate contacts is a PCI connector.
I'm not that keen on slimming the board down to 2 layers... because of the busses running down both sides of the chips, running power lines might not be possible... I suppose theoretically I could move the busses to a single side, but I'm pretty sure I would still wind up using both layers for signal traces, which makes running power and ground planes a pain.
But I'll keep thinking about it... I really want to see this project to the end, I was just hoping it would be cheaper so others could also build one of their own.
