Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Manufacturing & Assembly
have you recently tried filtering Digikey for 100nF-X7R-50V-0603 capacitors?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: have you recently tried filtering Digikey for 100nF-X7R-50V-0603 capacitors? (Read 2004 times)
tatus1969
Super Contributor
Country:
Resistance is futile - We Are The Watt.
on:
May 15, 2018, 09:35:01 pm »
The result is a bit frightening
Last Edit: May 15, 2018, 09:39:58 pm by tatus1969
Logged
We Are The Watt - Resistance Is Futile!
tszaboo
Super Contributor
Country:
Current job: ATEX product design
Re: have you recently tried filtering Digikey for 100nF-X7R-50V-0603 capacitors?
Reply #1 on:
May 15, 2018, 10:05:38 pm »
Buy it in different packaging...
Logged
edavid
Super Contributor
Country:
Reply #2 on:
May 15, 2018, 11:08:52 pm »
Previous thread:
https://www.eevblog.com/forum/projects/has-the-world-run-out-of-100nf-caps/
Logged
xaxaxa
Regular Contributor
Country:
Reply #3 on:
May 16, 2018, 03:25:18 am »
life hack: use 220nf caps instead of 100nf when 100nf runs out; check your design first though.
Logged
tatus1969
Super Contributor
Country:
Reply #4 on:
May 16, 2018, 08:39:02 am »
Quote from: NANDBlog on May 15, 2018, 10:05:38 pm
They have them in cut tape, which is what I went for. Just wanted to share this to see if this is a real problem "in the world". It apparently is...
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
