Author Topic: 0805 Cap, resistor, or ferrite bead  (Read 478 times)
Offline FaringdonTopic starter
« on: June 01, 2023, 07:03:10 pm »
An 0805 resistor is the same size as an 0805 cap...so why do all companies have separate footprints for 0805 caps and resistors etc?
'Perfection' is the enemy of 'perfectly satisfactory'
Offline ataradov
    • Personal site
Re: 0805 Cap, resistor, or ferrite bead
« Reply #1 on: June 01, 2023, 07:47:52 pm »
Because 0805 only describes the outside dimension, not the recommended pad size. Resistors and capacitors have different soldering recommendations.
And another side benefit is that you can assign a 3D model corresponding to the actual component type.
Alex
The following users thanked this post: thm_w, Faringdon
Offline thm_w
  • Non-expert
« Reply #2 on: June 01, 2023, 09:22:06 pm »
Capacitors are usually taller. If you google you can find hundreds of discussions about this.
https://electronics.stackexchange.com/questions/263129/why-do-kicads-library-footprints-for-0402-resistors-and-capacitors-have-differe
The following users thanked this post: Faringdon
