Author Topic: How might PCB be damaged in production?  (Read 1041 times)
Offline Faringdon
« on: August 17, 2022, 01:17:42 pm »
We ordered a PCB from a small supplier  and they said because it is 495mm x 185mm it may get damaged during production. They are making 5 of them for us.
Do you know what kind of damage they are referring to?
The board is 4 layer. It is a simple SMPS board. Min space = 0.3mm, Min drill = 0.6mm.
Copper = 1oz all layers.
Thickness = 1.6mm
I wonder if we had ordered it with 0.5oz inner layer copper things would have been ok?
Anyway, it sounds like they just wonrt ship the board if it is damaged?...but will give us a coupon instead.
This is what they said....(we asked them the questions but they havent got back yet)
Since you have ordered a large board size over 250x200mm, there is a risk that the board might get damaged during the production process. And normally we combine other customer's boards and produce them all together, so once one board gets damaged , we will not able to remake this board, in this case, when it happens , we will offer a coupon for your lost PCB and ship the good ones, is that ok for you ?
Sure please don’t worry , we will try our best to make the board in each steps and try to avoid the damage happens.
Offline temperance
Re: How might PCB be damaged in production?
« Reply #1 on: August 17, 2022, 01:43:53 pm »
Board rigidity it not defined by copper weight but more about the amount of glass fiber.
Why don't you ask your supplier those questions? They know their machines and materials and we don't.
Do you agree with this simple observation?
My name is Kafka and I will say it only once.
The following users thanked this post: Faringdon
Offline Jackster
    • PCBA.UK
« Reply #2 on: August 17, 2022, 01:50:49 pm »
Scuff marks from panels rubbing are pretty common with lower-end (cheaper) manufacturers.
We see this a lot from the likes of JLCPCB for example.
Actual damage to traces or pads that would void the board/panel can happen due to mishandling or alignment issues when making each layer and general quality issues derived from the quality of the production line.
Sometimes boards warp due to bad storage, being dropped or some material defects. Less common, more typicall in transport when they vacume them.
Poor handling can lead to damaged edges and corners. Less of a problem with rails but even so, this should not happen.
Really they should just run that panel again to get you the 5 boards you ordered. If you only need one or two of them then yea, take the coupon.
But really, if you order 5, you should get 5. This is them trying to save money on a 6th panel. Granted the smaller quantity orders like 5-10 boards, there is not much if any money in it for them.
We sometimes get 1-5 extra boards from the manufacturer if they have had to run the panel again due to one or more boards within the panel being bad.
Do share who you are using. Someone might have more insight into their process and quality.
The board being X size should not matter. More concerned about the quality of their production line if thin longboards are a problem for them...
Sounds like they are not too confident in it themselves.
Offline SMTech
« Reply #3 on: August 17, 2022, 01:57:49 pm »
Its sounds like they are risk/cost averse to having your PCB take up such a large proportion of their multi-design panel to me, bit like a silicon defect affecting yield in a wafer. I don't think we've ever had that kind of response from PCBWay and we order larger than that. (also since when was 250*200 large?)
Curiosity would ask who this manufacturer is?
Offline jmelson
« Reply #4 on: August 17, 2022, 02:55:18 pm »
You need to find a better fabricator for your boards.  This outfit is a hack!  They can't guarantee they can produce a board for you!
Jon
Offline IconicPCB
« Reply #5 on: August 18, 2022, 12:02:44 pm »
Since it is a multilayer board their tooling/inner layer registration setup may not necessarily guarantee proper layer registration across the width of a full panel.
Offline Faringdon
« Reply #6 on: August 24, 2022, 05:05:22 pm »
If you want a cheap 4 layer PCB, and really you want 1oz on all 4 layers.........is it true though, that the far cheaper and more common option is 1oz outer, 0.5oz inner?........and the 1oz inner needs the 0.5oz inner to be plated up to 1oz, and as such involves an extra production step which may result in mistakes in the board due to eg alignment problems?
Offline floobydust
« Reply #7 on: August 24, 2022, 08:49:34 pm »
A near 500mm (19") PC board with 1.6mm laminate and lots of heavy through-hole parts is simply going to flex to much and break things  :scared:  During handling, assembly etc.
You have to go thicker, stop being cheap. I use double (1/8" or 3.2mm) thickness laminate. As well as base 2oz copper for the outer layers, with your expected high currents.
Misalignment due to extra copper plating is the least of your worries I think.
Offline Faringdon
« Reply #8 on: August 25, 2022, 02:45:36 pm »
Thanks, yes i  agree, the latest board is 210mm by 400mm (less than half the size of the previous) and all surface mount PCBs are on "platform"  PCBs which are soldered in via thru hole headers. So i have to confess to cheaping it with 1.6mm PCB thickness's, but have taken the further precautions. There are also some 15 "feet" for the board, spread out. Effectively the SMD PCBs are 3.2mm thick as they are 1.6mm PCB on top of a 1.6mm  "platform" PCB. They solder to the platform via kind of "legs", like SMD legs, kind of. (there are SMD pads on both "platform PCB" and "SMD PCBs"), for these  "legs").
« Last Edit: August 25, 2022, 02:48:27 pm by Faringdon »
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #9 on: August 25, 2022, 04:01:46 pm »
Usually, pooled proto services make just enough panels, cut them out, inspect and ship.  Whichever parts either aren't needed by the customer (ordered less qty) or fail test (due to whatever reason, poor photography, blemishes, torn/cracked foil, blisters, gross breakage..), those are simply discarded.
Sometimes you'll be shipped the extras, because yield was better than average and, hey, why not, they have no use for them.
Have heard of one customer receiving a few panels worth (custom panelized build not proto in this case), that returned more units than ordered; the extras were just marked with big black 'X's, but were otherwise perfectly serviceable.
1oz sounds quite thin for the power levels you're working at.  Maybe that's okay, it's 4 layers; others have managed with less before (say 1oz 1-layer, albeit usually at lower power levels; still, have seen that up to, what, 500W or so?).  But that's very much another warning sign, you may want to put more consideration into the layout and stackup of the board, along with, y'know, everything else in your design.  And, budgeting accordingly.
Seven Transistor Labs, LLC
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #10 on: August 25, 2022, 05:52:03 pm »
They probably mean that they may have some panels that fail bare-board test, higher probability on a larger board. They will usually refund for any bad panels, but that may not help if you really need all of the panels.
Day Job: Mostly LEDs
