Good day All,
Just an update to this...
a. So, Loctite,Henkel's GC10 was sold to another company and this explains why a number of disti's are showing that the item is obsolete. As mentioned by member Mon2, AdTool does carry GC 10. However, the new GC10 manufacturer does not (currently) offer T5 size, only T4 and T3 and so this may or may not be an issue for some.
b. I tried Chip Quik TS391SNL250 T4 as mentioned above and it is also thermally stable and so it does not have to be refrigerated and it also has a 1 year lifetime. In using the CQ TS391SNL250, I found that its slouch time is significantly less than the GC10. For me having a longer slouch time is important, as I use both a PnP and hand placements when I am prototyping and for short production runs. That said, the CQ paste did hold up well and I did not have any real solder bridges after reflow... despite a total placement time of about an hour. I will be buying a new jar of GC10 T4 this week and so I will be able to see if the new company has modified its formulations with respect to the slouch time. I will report back with my experiences.
c. I was unable to quickly locate the NP-545 mentioned above, as I would have liked to try it. My CM uses Alpha paste and so I will try it too... when I get a chance.
Thanks to all that posted!
Cheers,
Sam
