Author Topic: Do tool-less PCB standoffs exist?  (Read 2368 times)
Offline e100Topic starter
« on: June 05, 2021, 04:56:24 am »
Something like this loud speaker grill attachment post and socket, but designed for thin FR4 instead of thick wood.
Obviously it's not as secure as the latching kind, but good enough for a home project where you know it isn't going to be subject to transport shock and vibration.
Online fourfathom
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Re: Do tool-less PCB standoffs exist?
« Reply #2 on: June 05, 2021, 06:06:27 am »
Something like these?
Those are the latching kind that require a pair of pliers to release the board.
I'm looking for something that you can just pull away (with sufficient force).
« Last Edit: June 05, 2021, 06:09:32 am by e100 »
Offline tautech
« Reply #3 on: June 05, 2021, 07:28:52 am »
Sure but there are 2 ways to solve that:
1. Make up a hollow release tool that depresses the lugs enough to pull the PCB from the post.
2. File or scalpel the lugs to allow for easy release of the PCB with just some small pull.
Avid Rabid Hobbyist
« Reply #4 on: June 05, 2021, 10:16:35 am »
Requiring the use of a tool would make it the opposite of tool-less (as mentioned in the subject line).
Unsupported nylon is difficult to modify by hand. Essentially you would have to attempt to replicate the design of the speaker grill posts.
Offline themadhippy
« Reply #5 on: June 05, 2021, 12:08:04 pm »
tool less as in needing no tools to fit,or is using a tool to initially fit them allowed? if no tools adhesive base stand off pillars with an m4 male thread and m4 nylon wing nut,not pull and pray but definatley tool less
« Reply #6 on: June 05, 2021, 02:26:55 pm »
Tool-less once fitted. A quick release system for boards that don't need to be held with an iron grip.
Offline ebastler
« Reply #7 on: June 05, 2021, 03:33:16 pm »
This kind can be unlocked (on the one side) with just your fingers, in my experience:
The following users thanked this post: thm_w, tautech
Online Alex Eisenhut
  • Place text here.
« Reply #8 on: June 05, 2021, 07:46:22 pm »
If you can find the service manual for the Commodore SX-64 maybe they will be identified. The boards hold in place with these funny MasterMind-looking pins...
On the right.
These go into a plastic tube that splits open and keeps stuff together. They can be removed with your fingers, assuming you have a mm or so of nail.
I could take pics but my SX is buried.
here's a pic I found, look on the lower left for a shiny black round object
« Reply #9 on: June 06, 2021, 01:03:51 am »
Found the manual https://manualzz.com/doc/57507047/commodore-sx-64-installation-instructions
Commodore calls them "plastic lacks". I did a Google search but that name doesn't give any results. Perhaps it was something that Commodore made for themselves.
  • Place text here.
« Reply #10 on: June 06, 2021, 01:34:04 am »
https://za.rs-online.com/web/p/rivets/0280874/
Maybe? I don't know. It's not really a stand off, but maybe this can get your search going.
Maybe go to Richco's site.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #11 on: June 06, 2021, 01:34:26 am »
Consider snap mounts, like the nylon bits above, but simply tapered, no latchy bit:
https://www.digikey.com/en/products/detail/keystone-electronics/8882/2345366
(fourfathom had the same idea)
Or the plastic rivet things,
https://www.digikey.com/en/products/detail/essentra-components/RS205W/9342607
the mushroom ones like this can be done by hand, if maybe not the easiest.  They're kind of pricey.  The pin ones seem to say "tool required", probably just for release though?  I mean, pushing isn't going to be the easiest, you probably want a screwdriver or something to bear down on, but that's pretty generic, like a chopstick would do.
(Alex beat me by seconds, :-DD )
Ed: and if you don't mind that tools are needed for installation of the hardware, consider lots of things that thread or press in.  Like the metal kind by PEM: https://www.pemnet.com/fastening_products/pdf/kdata.pdf
« Last Edit: June 06, 2021, 01:37:34 am by T3sl4co1l »
Seven Transistor Labs, LLC
« Reply #12 on: June 06, 2021, 04:23:26 am »
Snap-top standoff fasteners seem to be the closest to what I need.
SNAP-TOPĀ® is a registered trade name, is there a generic or alternative name to search for?
https://appianfasteners.com/pub/media/downloads/ssadata.pdf
« Last Edit: June 06, 2021, 04:31:44 am by e100 »
  • Place text here.
Online tszaboo
« Reply #14 on: June 06, 2021, 06:31:12 am »
Look at Essentra components website, they probably have the largest selection.
Offline mon2
« Reply #15 on: June 06, 2021, 10:35:04 pm »
Try the following vendors - have purchased from Judy many times - have met them many times at the HK trade fairs - they are a solid supplier and manufacturer:
yanJudy <judyyan7@hotmail.com>
Mobile:+86-13760455814
Skype:judyyan7
MSN:judyyan7@hotmail.com
Wb:www.yazhoulong.com
Shenzhen Yazhoulong Electronics Technology Co.,Ltd.
Add:13/B Fuhua Industry District Tangwei Fuyong Shenzhen 518103,China
also perhaps the largest in the industry:
https://www.kangyang-usa.com/
They are a Taiwanese firm and they usually sponsor the Taitronics Trade fair in Taipei. Every visit we made to this fair, their hand bags were given to all attendees.
Offline T3sl4co1l
« Reply #16 on: June 07, 2021, 03:44:18 am »
Taiwanese, with Shenzen offices?  Excuse me if I'm skeptical...
(I have no actual idea what their policy is as far as business relations with Taiwan, curious to know.)
Offline ebastler
« Reply #17 on: June 07, 2021, 05:27:09 am »
mon2 was talking about two separate companies there, as alternative vendor options -- Judy's company in China/Shenzen and Kangyang in Taiwan.
Offline T3sl4co1l
« Reply #18 on: June 07, 2021, 04:52:41 pm »
Ah, "also" indeed.
Offline ijchan223
« Reply #19 on: June 12, 2021, 02:07:00 am »
