I was looking at the Elecrow Gerber files requirements and this is what I have found on the site:
1. Gerber Files Required
The following files would be needed for the PCB production:
Top layer: pcbname.GTL
Bottom layer: pcbname.GBL
Solder Stop Mask top: pcbname.GTS
Solder Stop Mask Bottom: pcbname.GBS
Silk Top: pcbname.GTO
Silk Bottom: pcbname.GBO
NC Drill: pcbname.TXT
Mechanical layer : pcbname.GML
Does anyone know how strict this is? I make PCB's in Diptrace and when I export a board the output files look like this :
Through.drl
BoardOutline.gbr
BottomMask.gbr
BottomSilk.gbr
Bottom.gbr
Top.gbr
TopMask.gbr
TopSilk.gbr
For other PCB vendors (AllPCB, Seeed) I have put these files in a zip and that worked, I got perfect boards.
Would like to try Elecrow but if they are strict I have to rename the gerber files. Anyone any experiance with this?
Thanks.
