Author Topic: HWGC P&P machines - Documentation, Discussion and Info  (Read 105194 times)
Offline stefangem
    • cnc-technics.de
Re: HWGC P&P machines - Documentation, Discussion and Info
« Reply #350 on: May 25, 2024, 01:41:48 pm »
Hello,
can you me help to create a PCB Array. in the manual is this false. I have the smt550.
i will make 2 PCB in X (next to each other). in the software comes always "cannot Edit" when i will GEN PCB.
what are the instructions?
first from the first pcb to a fiducial and than the second pcb to the same fiducial?and than generate?
this has no function. always "cannot edit"
when i make on the plate a IC is this not a problem. but the fuction to make a pcb array is very difficult.
Regards
Stefan
« Last Edit: May 25, 2024, 02:27:42 pm by stefangem »
Offline JacksterTopic starter
    • PCBA.UK
« Reply #351 on: May 26, 2024, 12:10:22 pm »
Hello,
Regards
Stefan
You have to do it during the setup steps after setting the Mark fedicuals.
Offline 48X24X48X
  • Country: my
    • Rocket Scream
« Reply #352 on: May 26, 2024, 12:11:57 pm »
Hello,
Regards
Stefan
I think I have this panel instruction in my videos. Check them out.
Offline stefangem
    • cnc-technics.de
« Reply #353 on: May 30, 2024, 10:37:01 am »
I have done.
you have to mark the fiducial first and go to PCB Array, then the first and the last PCB mark from th fiducials.
