Author Topic: DIY Vacuum Pick Up Tool  (Read 1050 times)
Offline JanTheVan
« on: February 26, 2019, 02:14:21 pm »
Hi All,
Looking to make a Vacuum pick up for SMT, 0603 is the smallest component.
Would this pump be suitable or overkill?
https://www.rapidonline.com/rvfm-gp14008-vacuum-pump-with-300ml-mineral-oil-52-2210
Thanks in advance,
Scott
Offline graybeard
  • Senior III-V RF/mixed signal/device engineer
    • Chris Grossman
Re: DIY Vacuum Pick Up Tool
« Reply #1 on: March 03, 2019, 06:39:48 am »
That is overkill.   The is a roughing pump for a vacuum system.  I would work.  You would want to put inline filters so as not to suck dust and particles into the pump.
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: March 03, 2019, 06:47:31 am »
that pump i use to withdraw air from aircon system. i also have this, think much better for your purpose, and much cheaper...
https://www.ebay.com.my/itm/DC12V-Mini-Vacuum-Pump-Negative-Pressure-Suction-Pump-5L-min-120kpa-With-Holder/122072411176?hash=item1c6c152c28:g:Y1YAAOSwHodcdSBR:rk:1:pf:0
if something can select, how cant it be intelligent? if something is intelligent, how cant it exist?
Offline graybeard
    • Chris Grossman
« Reply #3 on: March 03, 2019, 05:13:12 pm »
That one looks perfect for a pick-up tool, and reasonably priced as well.
Offline MarkF
« Reply #4 on: March 03, 2019, 07:06:35 pm »
You may find this video interesting
Offline SteveyG
« Reply #5 on: March 24, 2019, 10:23:45 am »
I personally wouldn't recommend a piston pump like that, a diaphragm pump will be quieter and a bit more amenable to continuous use under vacuum.
