While I was designing a small PCB I was looking for a small smd push button, like those that are usually mounted on most MCU dev boards (arduino kind) as reset buttons.
Well, I thought "there is for sure some standard for this". Couldn't be more wrong, as it seems.
So my idea is: Is there any "multipurpose footprint" which can be used for a bunch of those pushbuttons (in the range of 3 by 2 mm, +1mm in both directions), so that there is no need to edit the PCB any time there has to be placed another type of button?
Best I found so far is this:
https://configured-product-images.s3.amazonaws.com/Datasheets/TL1017.pdfAt least one could use all buttons f that series by using the 3 pad footprint with tho hole in the middle. As long as one pin is ground anyways, that could be done.
Even better would be a footprint which is usable for different manufacturers.
Any hints or solutions for that approach?
