Yes, I checked. It's tight, but the source gerbers do not overlap - they also changed the line thickness visibly on the altered silk.
Some of my thinner lines haven't come out consistently so I guess I was right on the edge.
Would you post a picture of how it is and how it should've been?
Apologies for the differing angles - this is more or less the product of taking 50 shots and looking for the best. A phone is not a camera. A phone is not a camera. A phone is not a camera.
The JLCPCB appears to be an actual silkscreening process and leaky around the edges, making it very hard to read unmagnified - but every line is present and accounted for.
ALLPCB appears to be inkjet style printing and the resolution just wasn't up to the details I asked for. Not 100% sure the size has been changed now I can compare it better, but it's very inconsistent and that overlap shouldn't exist.
For comparison, the same size and settings on an unrelated board produced by DirtyPCBs. Looks like silk, somewhat cleaner than JLCPCB. Still a little thick, but very readable by eye.
And finally a shot of the same area from the gerbers.
I am asking a lot of bargain basement production: Those are 0.1mm thick lines around the 0603 footprints - ALLPCB can't consistently print them (their spec is >=0.15mm) and the other fabs appear to print them rather thick.
No real complaints with any of them - The silk's a bit crusty from JLCPCB, but they managed to get mask under one awkward footprint that ALLPCB gave up on. Both had some difficulties with the smaller of my plated slots - and DirtyPCBs had an issue with milling them at an angle on that board over two different runs.. They're all pretty amazing for what they charge.
