- If you want to be code compliant (USA) [select icon:
], dryer vents shall be independent of all other systems and convey moisture to the ouside of the structure.
- The dryer vent is likley coated with lint and it will receive moist air when the dryer is running. Depending on your fume compositions, the trapped lint could start to smell pretty bad and could also trap acids which will corrode the vent if it is metalic.
- If you use the dryer venting, think about ensuring there is no back-flow, install a damper/diverter, and ensure that the vent termination can't get blocked--such as a lint-filled grill at the terminus. Clean the vent out every now and then (robot project).
- If you don't want to run large ducting, transition the extractor duct into a smaller duct that uses a replacable, higher velocity in-line fan.
[corrected typos]
