What's everyone's thoughts on an online order form that keeps things as simple as possible. I realize everyone has their own preference with regards to customizing their PCB order to exact specifications, but would you be more inclined to just upload your gerbers (or better yet just your .pcb or .brd files), select your order quantity, and let us handle the rest?
Here's one thing I'm currently brainstorming:
Only manufacture boards that are less than 10x10cm with 1 to 2 layers, green solder mask, HASL lead free surface finish, white silkscreen, 0.6mm thickness, and 1oz copper trace.
If your PCB design is less than or equal to 10x10cm and has no more than 2 layers, and you're cool with the way we manufacture the board (as described above), all you'd have to do is upload your design files.
I'm looking to make this site really fast and easy to use. It's more for the hobbyist who isn't too worried about very detailed board specifications, or the designer that's working through prototypes for a new design that they need to test.
