"Automatic cooling mode protects the heating element "
"Heat switches off when air gun is in holder and switches on again when the gun is taken out for use"
There is going to be a hall effect sensor or reed switch in that area of the holder. Try tapping it or putting a magnet there. Maybe something loose inside.
Assuming you've properly set the temperature and airflow settings.
