Also, since you are making you own, you can do fun things like make solderable jumpers to ground on the board, to connect the right pin(s) to board ground. Then places for each pin to ground via a 0806 Cap, so you can do your decoupling close to the chip. This could be done on the bottom side of the board, under the IC, if needed.
