If profile in theXY plane is same , simply copmplete the pass art a fixed Z value and then repeat at a new Z value .
The new value will be determined by the cutter You are using and the chip load it can tolerate.
Dont forget the weave and weft of FR4 will present significant load as the tool cuts into it.
