Attached are pictures of the hardware disassembled.
One picture shows the order of how the parts go with the arm bracket between the two washers. As for a label or model name, I'll look underneath, maybe it's carved on the underside, but I've looked most places and haven't seen anything.
When I tighten the black lever, the head remains in position, but isn't very strong and slips with the slightest touch. Prior to that, I never had an issue, and then suddenly it just slid down.
If you look at the hardware, it looks like it's held in place by nothing more than friction which is why I suspect the washers need replacement, however, they don't look worn.
I can try a bolt and nut, but I'd be reluctant do torque it anymore than I have with the black lever due to the possibility of it cracking.
