A few years back, I started this project. The original intention was to see how far I could
push the envelope of LED efficiency. The original (and current) test bed is a 100mm x 100mm board from JLCPCB. Flash forward to 2024, For a variety of reasons, I decided back in March that the time had arrived to move from car-brain to bike-brain. As part of that, I found that forward illumination was needed for my recumbent trike. Most bicycle lighting is built for two-wheels with a steering post front and center. Then I thought about what could be accomplished with the light panel test board.
What was needed was a project box to hold a 100mm x 100mm PCB, and some form of clear front. 3D printing of opaque items is mostly straight forward, but printing transparent less so. On Aliexpress I found some 115mm x 115mm ABS boxes. Depth seemed to be sufficient, so I ordered a few. Today they arrived. As expected the PCB will not fit squarely (because the clearance between posts is 97mm), but as I crossed my fingers and hoped for, the PCB will fit slightly rotated. The rear of the PCB is a solid blank solder mask, so mounting the PCB with some double sided sticky pads doesn't bother me.
My question now has to do with the front. The existing front panel is the same opaque slightly off white plastic. Maybe 60 miles from me is a place [1] that seems to have an extensive selection of clear plastic sheeting. What I need to know is which of these is most likely to be UV resistant, and will remain transparent when subjected to sunlight. Two of these boxes will be mounted on the front outriggers on my recumbent trike. The expectation is to cut the clear plastic to 115mm x 115mm, drill four holes, then use something similar to caulk, but not caulk, to assist in sealing the two layers together.
Total power dissipation (including the light output) is about 2.2w per PCB, so I'm not expecting heat build up to be an issue, but I do want to drill a very small weep hole on the bottom to allow any accumulated moisture to escape.
Looking for any other thoughts or ideas.
[1]
https://sibe-rplasticssupply.com/
