Author Topic: Stenciling an oddly shaped board (was: small quantities of GC10?)  (Read 5276 times)
Offline NorthGuy
Re: small quantities of GC10?
« Reply #25 on: August 19, 2019, 03:28:14 am »
Interesting. How much would you enlarge the outline relative to the real board? Zero? 10 mil? Presumably tight is good but interference fit is perhaps going to be too much.
I would probably go for 6 mil. Tighter fit will help stencil alignment. But too tight will make it difficult to take the board out. It always can be corrected with Dremmel if needed.
Offline mrpackethead
  • D Size Cell
Re: Stenciling an oddly shaped board (was: small quantities of GC10?)
« Reply #26 on: August 19, 2019, 03:46:06 am »
Tab routing is not 100% accurate. you'll need to allow for the variation in accuracy of both 'PCB's
Offline Koen
« Reply #27 on: August 19, 2019, 11:03:15 am »
Add two small holes in the PCB. Add them to the stencil. Order dowels 0.05mm smaller. Stack three PCBs, insert dowels, add stencil, print. No machine, no jig, no frame.
Offline Harjit
« Reply #28 on: September 10, 2019, 11:13:20 pm »
@Koen - on the shape @djacobow showed, how would you do that?
