Author Topic: Insulation of old reel of enamelled copper wire?  (Read 1688 times)
Offline FaringdonTopic starter
« on: January 24, 2024, 06:35:53 pm »
Our customer has found an old reel of enamelled copper wire marked..
"Rowan cable Products Ltd
PART 1230978 0.4MM
WIRE COPPER ENAMELLED”
Rowan cable Products Ltd exists no more, neither the given part number.
Is there any chance that the wire's insulation is any lower than those in the below from elektrisola ?
That would be 2300V for 0.4mm Grade 1 enamelled copper wire.
https://www.elektrisola.com/en/Products/Enamelled-Wire/Technical-Data
'Perfection' is the enemy of 'perfectly satisfactory'
Offline Gyro
Re: Insulation of old reel of enamelled copper wire?
« Reply #1 on: January 24, 2024, 07:04:14 pm »
Impossible to answer of course!  Use known current production products, not old unknown reels from who knows where!
Best Regards, Chris
The following users thanked this post: Faringdon
Offline Stray Electron
« Reply #2 on: January 24, 2024, 07:22:39 pm »
  I've never worked with that brand cable so I can't really answer your question directly but I worked with enamelled wire a very long time ago and I don't think that the insulation was rated at anywhere near 2300 volts!  Most electrical in the US today is only rated at 600 Volt insulation and it uses a much thinker insulation than the enamelled covered wire.
  My advice is that if you really want to attempt to use that cable then make a test stand with a variable AC output and test some samples and see what voltage the insulation fails at.  OTOH if you're building a commercial product and liability is a concern then you should forget that stuff and go buy wire with insulation that IS rated for the necessary voltage.
Offline audiotubes
  • Country: cz
« Reply #3 on: January 24, 2024, 07:39:22 pm »
PART 1230978 0.4MM
Not an answer to your question, but amateur radio operators and shortwave radio listeners would definitely be interested in enameled copper wire in good condition.
Some mumble-grumble number or years ago I made a 40M dipole out of enameled wire and it worked a hoot.
Worst case, I'm sure they can find a buyer on the 'bay.
I have taken apart more gear than many people. But I have put less gear back together than most people. So there is still room for improvement.
Online tggzzz
« Reply #4 on: January 24, 2024, 09:10:02 pm »
Yes, there is.
You are Your customer is an idiot for asking such a question.
In other words, a typical faringdon/treez/ocset question/troll.
The following users thanked this post: Kean, tooki, Faringdon
Offline Doctorandus_P
« Reply #5 on: January 24, 2024, 10:15:57 pm »
That's what I was thinking too.
The stuff is probably good enough for DIY applications, but for anything industrial or even commercial, labor costs are likely much more then a roll of copper, and recycling it makes more sense.
Offline jc101
« Reply #6 on: January 24, 2024, 10:45:37 pm »
Rowan Cable Products Ltd is still a company, albeit a dormant one.  According to Company's House, it seems to have spent much of its time dormant.
Dispose of it as a totally unknown thing, more so if it going anywhere near to mains power.
Online langwadt
« Reply #7 on: January 24, 2024, 10:53:26 pm »
Yes, there is.
and undoubtedly made up, for just that reason
Offline jonpaul
« Reply #8 on: January 26, 2024, 01:27:43 pm »
Old stock magnet wire will be susceptible to cracks in the insulation.
Just recycle and buy new wire
j
Jean-Paul  the Internet Dinosaur
« Reply #9 on: January 26, 2024, 07:05:42 pm »
Thanks,
Today i got an empty old solder spool....i then tightly wound a 4cm layer of the enamelled copper wire on the spool.
I then tightly wound another layer on top of it.
I then connected one coil to mains line, and the other to mains neutral(240vac). Also added a 500mA fuse.
When i switched the mains on.....there was no flashover...nothing happened. I then added a 10k resistor in the neutral line and probed it and confirmed that there was no leakage current flowing through it.
The end pieces of the wires got pretty badly kinked, and were against each other where they had been stressed and kinked..but no problem.
I did this with the 0.4mm and the 0.224mm enamelled copper wire
from Rowan Cable.
This shows IMHO that this kind of wire is ok for rough prototyping of SMPS
transformers for offline SMPS.
I confess that eg flyback peak drain voltages will be more voltage stress...but ive done it before and had no problem.
I think i need to repeat this with a mains doubler voltage rectifier, to get a nice 680V DC between the coils.
« Last Edit: January 27, 2024, 01:38:55 pm by Faringdon »
Online langwadt
« Reply #10 on: January 27, 2024, 12:38:42 am »
just keeps on getting more and more silly, undoubtedly on purpose ...
Offline Gyro
« Reply #11 on: January 27, 2024, 11:09:10 am »
Isn't it 'your customer' who has found this reel of old wire? It sounds like "rough prototyping" = production to me.
Of course 'the customer' is probably another of your flights of fantasy.
« Last Edit: January 27, 2024, 11:17:35 am by Gyro »
Best Regards, Chris
