Hello!
I finally have money for a decent soldering station!
I want something that will last a lifetime and is cartridge based (which is why I don’t pan to buy the Hakko 888).
I had a budget of €200, but I'm thinking of stretching it to get the JBC BT-2BQA (€215 + VAT), however, I'm confused because I've also seen the BT-2BWA on the market which is a little bit more expensive, €251 + VAT.
It appears to be the same station but with different branding. ¿Does anyone know if there is any real difference between the two?
I think this station is "officially" obsolete, but since it uses the same pen as the new JBC stations, the supply of replacement tips should last a long time.
What do you think? Should I pull the trigger on the JBC BT-2BQA?
I also looked at the Hakko 951 and 971 but I prefer JBC.
