I hope this section is the right one for the question: I frequently use UV-curing glue like acrylic resin or the K-300 glass glue which AFAIK is based on cyanoacrylate.
The acrylic resin has a wonderful hardness and mostly produces a non-sticky surface that seems to be safe to touch directly after curing. The disadvantage of the acrylic resin is that it is not primarily intended to be a glue, and so it has no good adhesion to smooth surfaces like metal or even other plastics.
The K-300 type has much better adhesion on different surfaces, but all variations I tested so far release a sticky and/or oily film on the cured material that smells a little bit like Marzipan. It´s really nasty on the skin and even if you wash it from the parts and from your hands it feels not safe to be in contact with these substances.
Do you know a UV-activated glue with good adhesion and with surfaces that are dry and clean?
