Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Manufacturing & Assembly
Hakko bcm/cm tips for fx-888d
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Hakko bcm/cm tips for fx-888d (Read 398 times)
braincat
Contributor
Country:
on:
December 15, 2024, 10:27:03 pm »
Hi All, any idea where to get this tip type? It has a hole in the middle for drag soldering. I could not find it available for fx-888d.
Are there replacements that could work with this soldering station?
Thanks!
Logged
aeg
Regular Contributor
Country:
Re: Hakko bcm/cm tips for fx-888d
Reply #1 on:
December 16, 2024, 01:32:03 am »
Jensen claims to have 1pcs 900M-T-3CM in stock. You could also consider Plato HS-0530 or HS-0531.
I tried 900M-T-3CM once or twice and didn't really like it. I have the best results with an ordinary conical (!) tip and plenty of liquid flux. Your mileage may vary.
Logged
braincat
Contributor
Country:
Reply #2 on:
December 16, 2024, 03:41:29 am »
Thanks for the recommendation.
Do you drag the conical tip across the pins, or solder pins one by one?
Logged
thm_w
Super Contributor
Country:
Non-expert
Reply #3 on:
December 16, 2024, 10:20:47 pm »
Drag across.
Single pin is not needed unless you are fixing the chip in place, or cleaning up a single bad joint or something.
Logged
Profile -> Modify profile -> Look and Layout -> Don't show users' signatures
aeg
Regular Contributor
Country:
Reply #4 on:
December 17, 2024, 01:01:43 am »
I drag across, then inspect and individually redo any pins that have bridges or look questionable.
Logged
braincat
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
