Author Topic: JLCPCB now do Aluminium PCBs!  (Read 4067 times)
Offline SteveyGTopic starter
  • Soldering Equipment Guru
« on: June 30, 2021, 10:17:10 am »
I just saw today JLCPCB are now offering low cost MCPCBs! I need to get a few orders in to compare against PCBWay, but this seems really good value. https://jlcpcb.com/cyt
Sadly at the moment, no ENIG finish or higher thermal conductivity options but this makes high power PCBs a bit more accessible to hobbyists.
« Last Edit: June 30, 2021, 10:31:19 am by SteveyG »
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
The following users thanked this post: thm_w, Kean, ANTALIFE, james_s, kingsolmn, Zoli
Re: JLCPCB now do Aluminium PCBs!
« Reply #1 on: June 30, 2021, 10:19:51 am »
Looks like even a large PCB comes in at a reasonable price. Shipping obviously increases the cost significantly though
« Last Edit: June 30, 2021, 10:27:32 am by SteveyG »
The following users thanked this post: kingsolmn
Online xavier60
« Reply #2 on: July 07, 2021, 02:34:47 am »
To do any thermal calculation, the 1W/mK spec is meaningless without knowing the dielectric's thickness.
Does anyone know?
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Online xavier60
« Reply #3 on: July 07, 2021, 03:01:12 am »
So far this is the only discussion that I have found that acknowledges the significance of the dielectric's thickness.
https://forum.seeedstudio.com/t/aluminum-pcb-thermal-conductivity/5758/6
Offline lordium
  • Country: cn
« Reply #4 on: July 07, 2021, 03:52:01 am »
Quick search gave some results. Run through your favorite translation program/plugin.
https://order.jlc.com/portal/server_guide_27793.html
The following users thanked this post: xavier60
Online xavier60
« Reply #5 on: July 07, 2021, 08:28:45 am »
From that order.jlc.com/ link.
" thermal insulation: is a layer of low thermal resistance thermal insulation material, thickness of 2-8mil"
PCBway say 120um for their 2W/mK material. Who really knows?
Next thing to deal with is how much heat spreading the copper contributes.
« Reply #6 on: July 10, 2021, 07:42:57 pm »
This is apparently what they're using
« Reply #7 on: July 10, 2021, 07:47:00 pm »
Dielectric material thickness is 100um for this PCB material
The following users thanked this post: xavier60, tinfever
