Author Topic: JLCPCB SMT Assembly Service  (Read 18594 times)
Offline SteveyG
« on: September 06, 2019, 07:44:22 am »
JLCPCB have finally launched the SMT assembly service for those outside of China.
[attachimg=1]
I placed an order yesterday, so I shall use this thread to show how things go.
Limitations are:
- SMT assembly limited to one side of the PCB only. If you have components on the other side you must assemble these yourself
- You cannot supply parts yourself, they must come from the JLCPCB component library which is a subset of components from LCSC
- SMT assembly only - no TH parts
- Unlimited number of basic components can be placed, but a maximum of 10 different types of "Extended" parts can be placed. Basic components look to be mainly standard passive parts.
The only problem I faced when ordering is the list of components that was in the Extended parts spreadsheet didn't match up with what was available when ordering. I originally designed the board with a BME280 sensor on it, switched over to the Sensirion SHT31 which was in the Extended parts database. When ordering, this part wasn't an option so will need to be assembled at my end.
If everything goes OK then PCBs might be in my hands in a week or so, so it should be interesting to see how it pans out and what the quality of the assembly is like.
I think the components accounted for around $60, so the actual assembly cost was around $24 on the 10 PCBs.
The following users thanked this post: liteyear
Offline tglev
Re: JLCPCB SMT Assembly Service
« Reply #1 on: September 06, 2019, 08:46:18 am »
How did you get past the first screen where you upload your gerbers?
The next button does not work for me.
Offline SteveyG
« Reply #2 on: September 06, 2019, 09:01:43 am »
Were you able to select all the PCB options and see a preview of the PCB?
Offline tglev
« Reply #3 on: September 06, 2019, 09:22:57 am »
Yes, that page worked as normal.
Was also able to select quanties, panel the pcb and so on.
Offline SteveyG
« Reply #4 on: September 06, 2019, 09:33:22 am »
So you managed to select the side to be assembled?
After that, you should be able to click "Next" to begin uploading the BOM and CPL files
Offline tglev
« Reply #5 on: September 06, 2019, 09:37:18 am »
That last part, where you can turn SMT assembly switch to "on", is completely invisible for me on the page.
It also does not show up after adding the gerbers.
Offline SteveyG
« Reply #6 on: September 06, 2019, 09:55:06 am »
Are you signed in to your account?
Offline tglev
« Reply #7 on: September 06, 2019, 11:15:48 am »
Yes
Offline DTJ
« Reply #8 on: September 06, 2019, 11:33:08 am »
I'll be interested to see how this goes.
I guess they will not buy in parts that are not in their standard stock?
How is this company for just supplying bare boards? Are they reliable?
Offline tglev
« Reply #9 on: September 06, 2019, 11:44:02 am »
They won't buy parts that aren't in their stock and they won't accept parts supplied externally by the customer.
I have found them quite reliable for just bare boards, have been using them for a while and the PCBs are great quality. Especially for their low price point.
The following users thanked this post: DTJ
Online 48X24X48X
  • Country: my
« Reply #10 on: September 06, 2019, 12:24:45 pm »
Can I use my own KiCad library but still use the parts from their list or it is strictly using their EasyEDA software only?
Offline tglev
« Reply #11 on: September 06, 2019, 12:36:52 pm »
You can use your own library.
What I have understood is that you can select which component goes where during the order process.
The following users thanked this post: 48X24X48X
Offline thinkfat
    • Matthias' Hackerst├╝bchen
« Reply #12 on: September 06, 2019, 12:59:19 pm »
I think their parts catalog is a bit too limited for me right now. I just checked one of my recent projects:
They have STM32F072 but only LQF, I want QFN
They have just one ISSI LED driver in their list and not the one I need.
They do have the LEDs I want, though ;)
Offline mskeete
« Reply #13 on: September 06, 2019, 03:15:18 pm »
Just finished placing two PCBA orders.
The first was easy, just a few passives.
On the second one, all the IC's were out of rotation (90 degrees one way or the other) compared to proteus.
I had to edit the placement file and reupload a few times until it looked right.
I'll post a pic of what turns up in the post
Offline ddavidebor
    • Fermium
« Reply #14 on: September 06, 2019, 03:52:20 pm »
What browser did you use?
Davide Bortolami,
Fermium LTD
Offline SteveyG
« Reply #15 on: September 06, 2019, 04:29:06 pm »
I had the same issue, but it got corrected during the audit.
Offline DBecker
« Reply #16 on: September 06, 2019, 06:02:30 pm »
They have a good selection of STM32 parts in their "basic" collection.  There are more in their "extended" range, but for many it would cost less to upgrade rather than pay a setup fee.
« Reply #17 on: September 06, 2019, 06:19:03 pm »
Watching this thread avidly. I've got a design on hold waiting for this. I've carefully picked parts from their parts library so I can low ball the turnaround cost.
Offline DBecker
« Reply #18 on: September 06, 2019, 06:51:33 pm »
Is there any easy way to search only for 'basic' (no setup fee) parts using their search engine?
What is the matching process from my BOM to their list?
Offline mskeete
« Reply #19 on: September 06, 2019, 07:23:03 pm »
Firefox. Yesterday I tried Firefox and Chrome
When back to using Firefox but deleted all my JLCPCB cookies
I was also in contact with support so maybe they fixed it for me
Offline voltsandjolts
« Reply #20 on: September 06, 2019, 07:54:21 pm »
I'd like an option to show only the 'basic' components.
I thought some AVRs would have been in the basic range, but no. All Microchip micros seem to be extended.
Another good reason to learn STM32 :P
Edit:
Is there a downloadable spreadsheet somewhere listing all the basic parts?
« Last Edit: September 06, 2019, 07:56:24 pm by voltsandjolts »
Offline SteveyG
« Reply #21 on: September 06, 2019, 08:12:32 pm »
Edit:
You can search for basic parts by clicking the checkbox when actually placing the order but not when searching on the main page. I will ask for the option to be added to the general search too.
Offline SteveyG
« Reply #22 on: September 06, 2019, 08:13:20 pm »
Mine will be a few days extra as I chose the ENIG option, but I'll report back as soon as I have news. I'll also be uploading a video as soon as the PCBs arrive.
« Reply #23 on: September 06, 2019, 08:30:57 pm »
Here's your choices for 'basic' (no extra setup charge) microcontrollers:
STM32
STM32F030F4P6TSSOP-20
STM32F030C8T6LQFP-48
STM32F103C8T6LQFP-48
STM32F103CBT6LQFP-48
STM32F103RCT6LQFP-64
STM32F103R8T6LQFP-64
STM32F103RBT6LQFP-64
STM32F103RET6LQFP-64
STM32F103VET6LQFP-100
STM32F103VCT6LQFP-100
STM32F103VBT6LQFP-100
STM32F103ZET6LQFP-144
STM32F107VCT6LQFP-100
STM32F405RGT6LQFP-64
STM32F407VGT6LQFP-100
STM32F407VET6LQFP-100
STM32F429ZGT6LQFP-144
STM32L151C8T6LQFP-48
STM8
STM8L051F3P6TRTSSOP-20
STM8L101F3P6TSSOP-20
STM8L152R8T6LQFP-64
STM8S003F3P6TRTSSOP-20
STM8S103F3P6TSSOP-20
STM8S105C6T6LQFP-48
STM8S105K6T6CLQFP-32
STM8S207R8T6LQFP-64
STC
STC15F2K60S2-28I
LQFP44
STC12C5A60S2-35I
LQFP44
STC89C52RC-40I   LQFP44
TI
MSP430F149IPMRG4
LQFP64
Offline SteveyG
« Reply #24 on: September 07, 2019, 06:56:25 am »
I got feedback that this is getting added to the web page now.
There is also a bug at the moment whereby you can only place a total of 10 extended parts, even if they are all the same item. This will be fixed also.
