Hi everyone,
I am sure that there is a topic like this, but I can not find it. Because of that, I start a new one. I am sorry for that.
I have a design that has 2X2cm dimensions. I want to produce a PCB that has 10X10cm dimensions and has 25 of my design. What should I do?
In JLCPCB, there are three options.
1. Single PCB
What if I create schematic and PCB has 10X10cm dimensions and has 25 of my design and I draw silkscreen lines to separate same design. Does it work? Do JLCPCB V-Cut?
2. Panel by Customer
What if I create schematic and PCB has 2X2cm dimensions and it is my own design. Then I choose Panel By Customer, and set column and row 5. Does it work? Do JLCPCB V-Cut?
3.Panel by JLCPCB
I do not want to use this option. Because it cost more and I can not afford it.
Thank you for your answers. I want to say that I am sorry for my grammer. I am not good at languages.
Note: I added a jpg file. I mean that when I say V-Cut. Maybe it does not call V-Cut.
