Author Topic: Laser cutter for stainless steel stencils  (Read 17661 times)
Offline olkipukkiTopic starter
« on: February 17, 2017, 06:34:38 pm »
The market is flooding with different sort of laser cutters and I wonder if somebody here own one to make in-house stencils.
What is price and operation cost starts from for a reasonable cutter and how easy to operate/maintain it?
Is it worth hassle rather than outsource to PCB house?
Thanks
Offline IconicPCB
Re: Laser cutter for stainless steel stencils
« Reply #1 on: February 17, 2017, 07:12:49 pm »
conventional CO2 laser will not touch stainless steel unless...
There is a surface treatment for stainlesss steel whihc will allow the CO2 laser to mark / cut stainless steel. The treatment is a spray pack of some black concoction. Itis sprayed on and when cutting completed it is removed.
Costs an arm and a leg.
A more apropriate laser source capable of cutting stainless steel is a fibre laser source..
A laser cut stencil cut locally in Brisbane willset you back at least a few hundred dollars. Owning and operating one.s own laser cutter might be economicaly viable under these costs. Asian sources will cut a stencil for a quarter of the price, With freight it works out at half the local cost. OK if planing in advance of a project, Otherwise local next day delivery may be essential.
Offline rx8pilot
« Reply #2 on: February 17, 2017, 07:55:20 pm »
I have never seen a 'low cost' laser that can cut stainless sheet. It takes a lot of power, excellent optics, and a specific wavelength to accomplish that.
« Reply #3 on: February 17, 2017, 08:11:57 pm »
In Europe, a bit more than a week of waiting and you can get a spencil for $50, for extra 25/30% - just few days door-to-door
Any hint on a starting price for a decent cutter?
Offline IconicPCB
« Reply #4 on: February 18, 2017, 05:35:17 am »
30Wattfiber laser will cut stencil happily.
A 30 watt reasonable chinese fiber laser source a few thousand dollars.
On top of that optics and movement.
Offline IconicPCB
« Reply #5 on: February 18, 2017, 05:57:28 am »
See Raycus fiber laser.
Offline rx8pilot
« Reply #6 on: February 18, 2017, 06:50:55 am »
I have a 45W CO2 Epilog laser that won't touch metal. I can use Cermark to mark the metal but that is it.
Offline Fred27
    • Fred's blog
« Reply #7 on: February 18, 2017, 10:53:28 am »
A hobby CO2 laser can cut mylar solder paste stencils. As rx8pilot states, it won't make any impact on metals.
Offline MagicSmoker
« Reply #8 on: February 18, 2017, 01:40:20 pm »
Near infrared is supposed to be best for cutting stainless steel, so that means Nd:YAG and fiber lasers, which tend to be really expensive.
BUT... kapton (polyimide) and mylar (polyester) both make very good stencils that can be used 100+ times and which can be cut with a cheap 30-60W sealed-tube CO2 laser. Epilog is one popular manufacturer of lasers that are good for this application, but there are others.
That said, it probably isn't economical to cut your own stencils unless you are designing dozens of boards per year OR you are willing to pay a huge premium to get a stencil immediately, but since a stencil isn't worth much without a board, you would also need to have rapid board prototyping capability as well... All in all, it's probably best to get stencils made by, e.g., http://ohararp.com/stencils/ (no affiliation, just a satisfied customer of their kapton stencils).
« Reply #9 on: February 18, 2017, 03:05:37 pm »
What is mean "really expensive" - are we talking 6 digits (and plus) or...
as mentioned by @blueskull a cheapest starts from $15K, so $25-$30K will take us closer to a decent?
Actually, I never tried kapton and mylar stencils (basically, any non-stainless steel). Would be okay for 0402 parts and similar?
Not sure if I need this since $40-$50 will get me one from EU supplier (more or less as Chinese cost if include all taxes, risks, duties and shipping).
How difficult to use and maintain a cutter? Are there a lot of changes and overhead (setup type, gerber-to-what-ever-cutter-accepted-format converting) to fit into an existing workflow?
As today, I generate a fabrication output and send these to a PCB manufacturier(-ies).
Offline MagicSmoker
« Reply #10 on: February 18, 2017, 10:35:37 pm »
...Actually, I never tried kapton and mylar stencils (basically, any non-stainless steel). Would be okay for 0402 parts and similar?
I've used kapton stencils for the initial prototypes of boards that had 0.65mm pitch QFP packages on them and the paste printed fine. I suspect going down to 0.5mm pitch would be risky, though. 0402 passives should be fine, too, but I never use anything smaller than 0603 so can't speak from experience.
Offline DerekG
  • Country: nf
« Reply #11 on: February 18, 2017, 10:54:03 pm »
I'm not sure how many you need to make but PCBWAY will supply you panelised stainless steel stencils for about US$40ea.
I also sat between Elvis & Bigfoot on the UFO.
Online jpanhalt
« Reply #12 on: February 19, 2017, 12:43:22 am »
Why does it have to be laser?  Why does it have to be stainless steel (which alloy?)
I am always reluctant to make a suggestion when someone with a problem tries to define the solution -- assuming of course that there must be good reasons behind that.   Why not etch or reverse electroplate the metal template?   Have you considered copper or even (maybe better) nickel instead of SS?  After all, if etching gives you the resolution you need for the PCB, why won't it give sufficient resolution for the template?
John
Offline DerekG
  • Country: nf
« Reply #13 on: February 19, 2017, 02:41:14 am »
It doesn't have to be laser cut, but the stencil shops are set up for this as it quick & accurate.
Stainless steel is generally used these days as it is very hard & lasts a long time. I actually prefer brass screens as they are easier to handle .......... but brass is not so common these days. Brass will still manage a few hundred thousand operations (if they are looked after) before they need replacing.
Offline IconicPCB
« Reply #14 on: February 19, 2017, 02:49:50 am »
I sometimes mill a stencil in double sided FR4 material ( 0.2mm thick ) as used in multilayer core production.
Would not use it on 0603 or finer pitch designs.
Offline DerekG
  • Country: nf
« Reply #15 on: February 19, 2017, 02:55:11 am »
Yes, good thinking. We do most of our stencils in 0.2mm to ensure enough solder paste gets laid down on the board for reliability in automotive/vibration environments.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #16 on: February 20, 2017, 09:18:14 am »
One possible route to low-cost metal stencils is photochemical etching - some commercial stencils are done this way.
You still have quite a lot of process optimisation to get it right though.
Day Job: Mostly LEDs
Offline awallin
« Reply #17 on: February 25, 2017, 10:59:51 am »
check this... plastic fantastic stencil with chinesium 40W co2 cutter
The following users thanked this post: Kean
Offline richardlawson1489
    • PCB Assembly
« Reply #18 on: March 15, 2017, 10:26:16 am »
Here is a reference for you, which may help you to find the Laser cutter. http://hackaday.com/2015/04/03/cutting-smt-stencils-with-a-laser/
Offline D3f1ant
  • Doing as little as possible, but no less.
« Reply #19 on: March 30, 2017, 02:36:58 am »
So does anybody know what the cheapest laser machine is that will cut stainless stencils?
« Last Edit: April 03, 2017, 03:51:42 am by D3f1ant »
Offline Smallsmt
« Reply #20 on: March 30, 2017, 05:11:30 am »
I don't know if it's cheap but GCC has good quality machines.
Please look at
http://www.gccworld.com/goods.php?act=view&no=22
Offline Spikee
« Reply #21 on: March 31, 2017, 10:04:03 am »
Stainless steel stencils are soo cheap from china that seems crazy to invest in such machine.
~15-20 usd for ~30*30 frame-less stencil 0.1mm thickness (0402, BGA... all ok) , DHL/FEDEX/SF EXPRESS/EMS/Cheap china AIR  shipped within 36-72 hours.
With about 20USD shipping cost for DHL to most places. Can probably even do combine shipping if your pcb also come from china.
« Last Edit: March 31, 2017, 10:05:53 am by Spikee »
Freelance electronics design service, Small batch assembly, Firmware / WEB / APP development. In Shenzhen China
Offline D3f1ant
« Reply #22 on: April 03, 2017, 03:51:04 am »
It's not so much about the cost, its the time it takes to get a replacement when there is design flaws. 2 or 3 days is a very long time to have machine sitting idle.
Offline OSHStencils
« Reply #23 on: April 19, 2017, 11:33:54 pm »
Thanks Blueskull, we do ship within 1 business day anywhere in the world and we utilize the best stencil cutting machine and metal on the market currently.
Our pricing is linear, and you only pay for what you need.  If you look on Twitter @OSHStencils you'll see lots of customer posted stencils, or our website in the gallery you will also see our product offerings.
Offline jmelson
« Reply #24 on: May 14, 2017, 04:06:41 am »
Yes, I make brass stencils form .003" brass shim stock, using the same technology for making PC boards.  I use Riston dry film resist, making a set of mirror-image artwork.  I glue the artwork in alignment, then slip the sensitized brass in between and expose and etch just like a PC board.
Works quite well.
Jon
