Each joint has different thermal properties, due to the mass of the component lead, trace width, nearby vias, etc. In hand soldering, we accommodate for this with different tip sizes/geometries, and with the temperature and dwell time.
I assume that in laser soldering, each joint’s thermal properties need to be individually programmed for good results.
